I've just installed Vanilla 2 and I'm trying to add some plugins. I was under the impression that I just had to upload the new plugins into the plugins folder (just like how wordpress plugins work), but I've done that and none of the new plugins are showing up. Am I doing something wrong?
The same thing is happening with my themes. I've added a theme, but it's still only showing the default theme in my dashboard...it's not showing the one that I added.
I'm new to Vanilla, but I've been a programmer for 10 years and I've also used Wordpress quite a bit, and I can't figure this one out.
Can someone perhaps direct me to the code that checks for plugins? Maybe a variable got screwed up and it's looking in the wrong place or something?
Ex. Say you want to add "attachments-ii-0.05.zip"
depending on how you extract it it may come out like this, Folder : "attachments-ii-0.05"
you want to open that folder and move the folder named : "AttachmentsTwo".
Hope this helped you.
The plugins are compatible for Vanilla 2 as is my version..
