I could really use some help. I downloaded a few add ons but I don't understand HOW to install them.
"it must be contained within it's own directory within the extensions directory. So, once you have downloaded and unzipped the extension files, you can then place the folder containing the default.php file into your installation of Vanilla. The path to your extension's default.php file should look like this:
I'm assuming you're using Vanilla 1, you didn't say...
Using an FTP client, log into your website, navigate to the extensions directory and upload the directory and files you extracted from the ZIP file you downloaded.
Then you click the Settings tab at the top of your forum and then select Extensions from the Panel (on the left by default). You should then see your extension in the main view.
In general, give more information with your problem and people will be able to give you better help. Things such as the version of Vanilla you are running, the name of the add-on you're trying to get working and its version number are all really useful bits of information. If possible, also give a link to you site!
Yes V-1, thanks!! OMG, I am so trying to understand stuff! Thanks! Okay, www.hcgdietjourney.com is the site Vanilla 1 was the download and it's several add ons I downloaded to add the the forum, side bar, google and one other. I'm on my laptop and I downloaded it all the the desktop. But I'll write back as I have to go to the desktop and follwo your screenshots.
