Bonk on post and view post
After getting past errors on installation, I'm having more problems. When starting discussion, I get the Bonk error, but it still creates the discussion. But I can't view it at all because the Bonk error comes up again when trying to view the discussion. Everything else is working fine. I've tried adding the $Configuration['Garden']['Errors']['MasterView'] = 'deverror.master.php'; line to my config file with no luck.
My server is running at least the minimum that Vanilla requires: PHP 5.2.6, MySQL 5, PDO, etc.
Any ideas?
Any ideas?
This happend for me when I tried accessing a deleted comment. So for you, I'd recommend to check if there is really any data in the database?
I'm going to try reinstalling and see if that helps.
