help! I moved vanilla to a sub dir and now I forgot which setting to change to make it work again!
edited July 2010 in Vanilla 2.0 - 2.8
Hi all
yeah, like the title said, the guys I am working with wanted to add another layer on top of the forum, so we moved the whole website into a sub dir. but now vanilla doesn't work anymore. then I remembered that there was some sort of settings that I was suppose to change, but I have forgotten. It has been a year since I had to go admin that forum in a technical capacity.
If any of you have any ideas as to how to fix this or what settings I should be changing, that would be great.
Thank you very much.
