In trying to make a french translation of Vanilla/Garden (still in work, but I will share it when it's done), and after having found help on this forum, I've made my own solution that is below :
1. Download and install
Undefined Translation Collector2. Enable it in the Plugins section of the Dashboard
3. Browse a maximum of pages in the conversations, discussions, and Dashboard
4. Go to the folder "plugins/TranslationCollector" and copy/paste the ApplicationName.php files into /applications/ApplicationName/locale/fr-FR/ and rename each file definitions.php
Don't forget to change "/fr-FR/" to your language like "/lang-COUNTRY/"
5. Translate each file
6. Add this lines in conf/config.php :
$Configuration['Garden']['Locale'] = 'fr-FR';
7. Delete library_mappings.php in /cache/ directory
8. Reload your community / forum and it's working fine !!!!
Sorry for this long explanation, but I think that is detailed enough ;-)
I hope this would help someone ;-)
Bests,
Arachnos
Just delete your library_mappings.php in your /cache/ directory.
Garden will rescan your folder structure and add all locale files for all applications and plugins.
Only a couple of things didn't get picked up by the Undefined Translation Collector:
- The "Sign In →" button in the popup box (probably caused by the arrow sign which is hard coded)
- Same with Search results text like "↳ No results for..."
- A lot of secondary stuff on the Recent Activity page (the lines in grey)
- The "Options" left panel header on the user profile page
- And checkboxes in the Signature options popup on the same page
Anyone know why, and how I can add translations for these?
Another thing: in Norwegian, Search = Søk, which I encode to Søk. It works on text, buttons, etc, but not in the search field, where it shows up character for character: "Søk". Any ideas for what I can do to make the search form accept HTML character entities?
@fredrikstai : I've too some problems like digits in "Enabled" / "Disabled" tabs, if you have some solution… It could be cool
Don't use ISO, use UTF-8 : it is better (and in French it prevent from having to code each accent, I think in Norwegian too like the "crossed o").
<?php if (!defined('APPLICATION')) exit(); ?>") of /applications/dashboard/views/entry/registercaptcha.php :<script type= "text/javascript">var RecaptchaOptions = {lang : 'fr'
</script>N.B. : replace 'fr' by you lang code (see http://www.google.com/recaptcha/apidocs/captcha/client)Feel free to make it even longer! :)
I don't know what's the ISO code for "↳"
If someone found the solution to translate counter digits in the Dashboard or in front office like "Enabled [digit]", share the solution with the community ;-)
