  • tmilovantmilovan
    This discussion is related to the Last Edited addon.
    Great you added "Last edited" functionality as a plugin. However, it works fine except for the discussion starting post.
  • MikhaelMikhael
    Works ok for me in the first discussion post @tmilovan. Maybe it's a clash with another plugin?
    What I did notice though, is that a tag which was assigned to a test discussion which had been deleted was still in the tag list, and the link went to a 'Not found' page. @Tim may like a peek at this?
  • TimTim
    This was fixed.
    Vanilla Forums Senior Developer [GitHub, Twitter, About.me]
  • @Mikhae: tried to disable them but witout success. But I have turned on Markdown input method. Can that be the reason?
  • tmilovantmilovan
    Just to bump this. It still does not work for discussion starting post on my forum. Vanilla 2.0.16.
    Also I have noticed that sometimes Markdown would not kick in for starter post too (but only sometimes, last edited never works). Can that be connected with the fact that I have migrated my forum from phpBB3.
  • judgejjudgej
    Is this a permission issue? I've not tried this plugin, but in the permissions screens is there a way to turn it on and off for discussions and comments across the categories?
  • tmilovantmilovan
    No. There is nothing in permissions screens.
  • I'm getting an error which seems to be associated with the first post, so I thought I would post it here:
    Fatal error: Call to a member function Get() on a non-object in /.../vanilla/plugins/LastEdited/class.lastedited.plugin.php on line 63
    I'm using the latest production release as of today's date.
  • @mostmodernist Did you convert a forum to Vanilla?
  • Hi there.
    I'm getting the same thing:
    I get an odd problem in that when I navigate away from my Vanilla forum to another open browser tab and then return later, a lightbox (popup) has appeared with the text from the first post in the discussion and then the fatal error at the bottom.
    I have the latest version of VF - installed last week...
    Has anyone got any closer to the solution for this one - I really liked this plugin (last edit) but might have to disable until I can fix this.
    Thanks for any help...
  • horia_mhoria_m
    I am getting this error too:
    Fatal error: Call to a member function Get() on a non-object in /home/libertat/public_html/platforma/forum/plugins/LastEdited/class.lastedited.plugin.php on line 63
    using Vanilla 2.0.17.8 and some other plugins, with the vanillapress2010 theme.
  • meadwaykmeadwayk
    I'm getting the same error as above as well, using vanilla 2.0.17.8.
    For the time being I've disabled the plugin but would like to know if a fix is coming?
  • TimTim
    Uploaded a small fix that should take care of that.
  • meadwaykmeadwayk
    have updated my plugin, enabled it and so far not getting any errors!
    many thanks for sorting this out...
  • horia_mhoria_m
    Dear Tim, thank you, this is great news!
    I will test it immediately and post a feedback.
  • horia_mhoria_m
    I updated the plugin, now everything works fine! Thank you!
Login with Facebook Sign In with Google Sign In with OpenID Sign In with Twitter
Who's Online 3
Raizepaintballer82422
