Who's Online 10
CurtisOdenericgillettex00 +7 guests
Problems upgrading from Vanilla 1.1.10 to 2.0.11
I've noticed some problems with the upgrading process and I'm not sure if the problems are unique to me or if they are just how it is.
Any comments would be helpful, and I might still have commit access to be able to change it, since I was a Vanilla 1 developer.
  1. Before the database import, users are able to register. After the import, registration is broken.
  2. Old users can no longer log in
  3. In the new installation, deleted comments are visible to everyone.
There were no errors during any step of the installation process, and it all works fine before the upgrade (on the fresh install of Vanilla 2.0.11) so I think it is probably a problem with the Vanilla export/import process and not my installation.
    Oo oo Mark pick me for a reply
  • TimTim
    Regarding 1) and 2), you might need to take a look at your Roles and Permissions. Make sure that your default user role has the Garden.Signin.Allow permission. Also make sure the registration is enabled and that the default new member role is correct.
    3) Would need to be answered / addressed by @Todd or @Lincoln
    Vanilla Forums Senior Developer [GitHub, Twitter, About.me]
    Hi Tim,
    Thanks for the reply.
    You're right about 1 and 2, that fixed it.
    An answer on 3 would be great since that is the last think that is preventing me from updating from 1 to 2, I think.
    Bump
    I have this discussion bookmarked for as soon as I can address it.
    Vanilla developer [GitHub, Twitter]
    @Lincoln: I have the time to look through the script, but I don't know where the build script for the importer is. If I can have access to that I can fix it myself.
    Absolutely, the source is here: http://github.com/lincolnwebs/VanillaPorter
    The vanilla2export file is the builder, but you probably just want the Vanilla 1 class.
    Send pull requests to the unstable branch (just like Garden).
    @Lincoln: Thanks, I'll post back if I have success
    @Lincoln: It seems that while Vanilla 1 soft-deletes comments, Vanilla 2 actually deletes them from the database.
    If it's by design then I think you can remove the DateDeleted column from the Comments table in Vanilla 2 since it seems redundant.
    Let me know if I'm misunderstanding, though.
    Anyway the fix for the importer is to replace line 154 in class.vanilla1.php,
    AND coalesce(c.WhisperUserID, 0) = 0", $Comment_Map);
    with:
    AND coalesce(c.Deleted, 0) = 0", $Comment_Map);
    I also added the updated export script to my blog here in case anyone wants to use the update before it is officially released.
    There may be plans to have a soft delete in the future, but you're correct that it does not currently. Thanks for the fix; I'll plan to get it in this weekend.
    @Lincoln: Sounds good, and yeah soft-delete would be cool too. There can be an option in the Dashboard to enable it since there are different opinions on what is better.
    Added to unstable branch for next version.
