Does Indentation work with <Embed> Vanilla
I've made the change to the helper_functions.php file.
Everything seems to be working the way I would expect except that replied to comments are inline as opposed to indented.
So does the indentation work with the WorPress embedded version of Vanilla 2?
Maybe you need to add that to the Embed theme? Not sure.
No indentation here. But I did not notice that anyone else was using ReplyTo with the WordPress embedded version of Vanilla, and so I asked.
I hope there is a fix...
I am guessing that either the stylesheet is missing, or the classes on the comments are missing, but you will need to look which it is (or point me in the direction of the site).
Thank you very much for the offer.
I would indeed be grateful if you looked at my site.
May I send you a private email because the site in question is a membership site?
Or you can reach me at: daniel.ferry@gmail.com
Thanks in advance.
