A small fix
This plugin doesn't work for me. After looking at the code I find this to fix it. Modify santahat.plugin.php:
Change line 24 to:
$Sender->AddCssFile('/plugins/SantaHat/design/santahat.css');
Change line 32 to:
echo Img('/plugins/SantaHat/design/'.$RandomHat, ArrayValue($RandomHat, self::$Hats));
  • Moderators please review and approve this plugin. It's very small with only some lines of code.
  • SS ✭✭
    It's weird. Hmm... why GetWebResource() doesn't return properly path to asset? @Tim
    @hoangminhthang
    Check your config.php
    If you have
    $Configuration['Garden']['WebRoot'] = '';
    Try to change it to $Configuration['Garden']['WebRoot'] = '/';
