need css help for discussion links
edited January 2011 in Vanilla 2.0 - 2.8
I want to change the color of the links only inside of the discussions themselves.
when I inspect element for the links using Firebug, I'm lead to this bit of code
a, a:link, a:visited, a:active { color: #000000;
I can't change that to the color I want, because it changes all the links throughout the site. I want to change only the links that are posted in comments. Right now, based on this code, they black, just like all the text. This is a major usability issue. What kind of code do I need to add to my theme (or wherever classes are defined) to isolate just the links inside the comments themselves?
    You need to add in Custom file just after :
    a,
    a:link,
    a:visited,
    a:active {
    color: #000000;
    that :
    .Message a, a:link, a:visited, a:active {
    color: #color-you-like;
    Image hosted by uppix.net
    But that change all the "a" of comment:
    so you need to add some infos :
    .Meta a{
    color: #same-color-of-"a=000000";
    And that:
    .Buttons a{
    And change the color of link in div.Box, so you need to add after:
    div.Box h4 {
    color:#282828;
    that:
    div.Box a{
    In code:
    div => #
    class => .
    after the name of "location" (here:Message), and the "objet" (here:a)
    This image has been resized. Click to enlarge.
    May be not the most simple code but it works.
    Sorry for my english. ^^
    @lena - thank you! Your response was thorough and educating! I was able to set it up in short time and I learned something from your comments about how to figure out css code.
    Thank you!
    @leafboxtea: my pleasure, you're welcome!^^
