Did the question of how to do this ever get resolved? I've not got 2.0.17.8 installed (really need to wait for the categories to settle down and be more stable first), so I can't test that, but I know there was discussion about how it would work.
2.0.13 Does not support sending out emails to users with spaces in their names. It makes sense to me to allow a plus (+) to be used to join the names together, e.g.
@Fred+Bloggs <--you can see the problem here already
Any ideas or does anyone know whether this now works in 2.0.17?
-- Jason
0 • •
Developer at Vanilla Forums, Inc. [GitHub, Twitter]
0 • Off Topic Insightful Awesome LOL •- Spam
0 • Off Topic Insightful Awesome LOL •I bet its only a couple of lines of code to do, and I'll post back here if I work out how.
0 • Off Topic Insightful Awesome LOL •The library/core/functions.general.php function GetMentions() contains the regular expression that finds usernames being mentioned in a post. I just replaced the bit that searches for a string of word character (\w) to a match that includes plus character ([\w\+]).
In that same function, any matching mentions that are to be returned, need the + converted back into a space. Everything after that then just works as normal. This function can be overridden in a plugin to avoid having to mess with the core.
Doing this has also highlighted several things to me. Firstly 2.0.13 does not handle mentions correctly (duplicate emails in some instances, and the mentions not being checked at all in some comments). The expression that is used to match a mention in a comment or discussion display is not changed, so this RE is duplicated elsewhere - both should really use the same bit of code, so that both functions can be overridden by a plugin in one go.
Lastly, this RE assumes usernames are between 3 and 20 characters (I assume it is international characters and not bytes!) long. his is an unnecessary and arbitrary limit. The username length should be defined in one central place IMO, and all references should go back there, including the creation of the username database column. I've increased mine to 40 characters already, because 20 was too short, and now I realise I need to search for other places where "20" is hard-coded in.
0 • Off Topic Insightful Awesome LOL •I've changed that, and now I'm happy :-)
0 • Off Topic Insightful Awesome LOL •Added to conf/bootstrap.before.php
if (!function_exists('ValidateUsername')) {
function ValidateUsername($Value, $Field = '') {
return ValidateRegex(
$Value,
'/^([\d\w_\+]{3,40})?$/si' // Include "+" and extend the username length
if (!function_exists('GetMentions')) {
function GetMentions_ConvertPlus(&$Value, $Key) {
$Value = str_replace('+', ' ', $Value);
function GetMentions($String) {
$Mentions = array();
// This one grabs mentions that start at the beginning of $String
preg_match_all(
'/(?:^|[\s,\.])@([\w\+]{3,40})\b/i', // Include "+" and extend the username length
$String,
$Matches
if (count($Matches) > 1) {
array_walk($Matches[1], 'GetMentions_ConvertPlus');
$Result = array_unique($Matches[1]);
return $Result;
return array();
Note the "40" above extends the length of the username to 40 chars (or bytes) and this also validates usernames with spaces in. Normally I use ProxyConnect, which bypasses this validation function, so my users have spaces in without this change. The database GDN_User.Name column also needs extending to 40 chars.
IMO the "40" (or "20" in the standard install) needs to be a central configuration item and not hard-coded in so many places.
A core change that cannot be added to the bootstrap is library/core/class.format.php Gdn.Format::mentions()
// Handle @mentions.
$Mixed = preg_replace(
'/(^|[\s,\.])@([\w\+]{3,40})\b/i', //{1,20} // JDJ Include "+" as a valid character
Anchor('\1@\2', '/profile/\\2'),
$Mixed
(Edit: just to show how blunt a tool the above is, the "@mentions" is being converted to a link to a non-existent profile page. It is in a code block for a start and demonstrates how poor regular expressions are at replacing text in structured documents - they just have no concept of context.)
This could possibly be made user to upgrade by using a "replace" hook for this function in a plugin (renaming the Mentions() method to xMentions() - I've not tried this though, and I have a feeling it may only work on models and controllers).
This is Vanilla 2.0.13, and that is where I will be stuck for a while, but Vanilla does seem to be changing fast.
I hope that helps.
0 • Off Topic Insightful Awesome LOL •http://www.vanilla-wiki.info/Bugs/VariousTips
0 • Off Topic Insightful Awesome LOL •if (!function_exists('ValidateUsername')) {
if (preg_match('/(^[ ]|[ ]{2}|[ ]$)/', $Value)) return FALSE; // JDJ Fail on leading, trailing or runs of spaces
$Value,
'/^([\d\w_ ]{3,40})?$/si' // JDJ Allow spaces and 40 char length
That is also assuming the username will get trimmed on input, so users cannot use spaces as prefixes or suffixes. In addition I would also disallow runs of more than one space, which could probably also be detected with the RE (pop-quiz exercise for a lazy Sunday!) but would be far easier and less prone to error just to use a string-search for two spaces.
Edit: I've added another
*untested*preg_match() to fail validation on fun being had with spaces.- Spam
0 • Off Topic Insightful Awesome LOL •"Problem solved" is always easy for a slightly different problem, and with different needs to start with ;-)
0 • Off Topic Insightful Awesome LOL •If you look at the username requirements in the latest version, you'll notice spaces are not allowed for new member sign-ups.
Sure, there are work-arounds with string manipulation when padding for @ mentions, but you may be causing yourself a legacy issue, especially as newer versions are released. Will your code patch work every time?
Twitter, where the @mention started, don't allow spaces in usernames for good reason.
0 • Off Topic Insightful Awesome LOL •I dont have conf/bootstrap.before.php
Its part of a plugin? Thanks
