images and youtube in posts on V1 are not seen after import to V2
HortonHorton New
edited March 2011 in Vanilla 2.0 - 2.8
I'm in the final phase of a migration from vanilla1 to vanilla 2.
I noticed tonight that images and youtube in posts on V1 are hidden in V2. I can add them back - embed, upload, whatever
The HTML is intact but he images are not exposed. I'm not using any add-on editor. I assume the error is between keyboard and chair that I have no idea.
    I really don't understand this now but is less of an issue. I can create a new post with HTML and images and shows up great. Any post that was imported from my vanilla one installation does not have the images. The strange part is if I open the old post and copy the HTML and paste it into a new thread everything is there. Strange but doesn't really matter.
    Did you figure this out Horton? Same issue here! :)
    edited April 2012
    I personally haven't moved from v1 to v2
    But this may provide a clue. Just an idea.
    Identify the comment id of the comment that has an image that does not show.
    Identify the comment id of the comment you just copied and pasted into a new comment that has an image that does show.
    compare the body column and the format columns of the two comment id's in the comment table and see if the tags are corrupted or if the format column is different.
    if you find a difference - you could export the body column and use a regex to fix the tags in php and then update the database with the fixed tags or maybe use a regex in sql update.
    I guess it was the formats column.
