Sudden strange issue renders my Vanilla installation unusable
I don't know what caused it, but from one moment to another the following happened: all URL's have the ampersands replaced into & (instead of just &).
Also, when I try to directly go to an URL like index.php?p=/dashboard/settings it redirects me to index.php?p=/forum/index.php&p=/entry/signin&%3BTarget=dashboard%2Fsettings
Anyone knows what could be causing this? The only thing I can remember is logging out to start styling the subscription form.
Optionszodiacdm ✭Try clearing your cach folder. I've heard that help a lot of people on this forum.0
But I think I solved the problem. It seemed that my configuration file on the testserver was overwritten by an older one on my local work environment. Therefore, some plugins/settings were incorrect.
Re-configuring Vanilla seemed to fixed the problem.
Reminds me I gotta fix that
