We are using Vanilla version 2.0.18b2 and users will post in Japanese language. The problem is that when doing a search, it will only find the exact phrase that was searched but not part of it (individual words).
For example, we can search for: いつもご利用ありがとうございます
But not this: いつも (which is part of this phrase)
I noticed in another post that someone had the same problem with Chinese and other unicode (multibyte) characters. Does anyone have any tips or a solution for this? Database is using utf-8 characters so I don't think there's a problem with database.
I have been checking the source files and I'm guessing that /applications/dashboard/models/class.searchmodel.php handles this but maybe we'd need to change something somewhere else?
Here's searchmodel.php:
class SearchModel extends Gdn_Model {
/// PROPERTIES ///
protected $_Parameters = array();
protected $_SearchSql = array();
protected $_SearchMode = 'match';
public $ForceSearchMode = '';
protected $_SearchText = '';
/// METHODS ///
public function AddSearch($Sql) {
$this->_SearchSql[] = $Sql;
/** Add the sql to perform a search.
@param Gdn_SQLDriver $Sql
@param string $Columns a comma seperated list of columns to search on.
public function AddMatchSql($Sql, $Columns, $LikeRelavenceColumn = '') {
if ($this->_SearchMode == 'like') {
if ($LikeRelavenceColumn)
$Sql->Select($LikeRelavenceColumn, '', 'Relavence');
else
$Sql->Select(1, '', 'Relavence');
$Sql->BeginWhereGroup();
$ColumnsArray = explode(',', $Columns);
foreach ($ColumnsArray as $Column) {
$Column = trim($Column);
$Param = $this->Parameter();
$Sql->OrWhere("$Column like $Param", NULL, FALSE, FALSE);
$Sql->EndWhereGroup();
} else {
$Boolean = $this->_SearchMode == 'boolean' ? ' in boolean mode' : '';
$Sql->Select($Columns, "match(%s) against($Param{$Boolean})", 'Relavence');
$Sql->Where("match($Columns) against ($Param{$Boolean})", NULL, FALSE, FALSE);
public function Parameter() {
$Parameter = ':Search'.count($this->_Parameters);
$this->_Parameters[$Parameter] = '';
return $Parameter;
public function Reset() {
$this->_Parameters = array();
$this->_SearchSql = '';
public function Search($Search, $Offset = 0, $Limit = 20) {
// If there are no searches then return an empty array.
if(trim($Search) == '')
return NULL;
// Figure out the exact search mode.
if ($this->ForceSearchMode)
$SearchMode = $this->ForceSearchMode;
else
$SearchMode = strtolower(C('Garden.Search.Mode', 'matchboolean'));
if ($SearchMode == 'matchboolean') {
if (strpos($Search, '+') !== FALSE || strpos($Search, '-') !== FALSE)
$SearchMode = 'boolean';
else
$SearcMode = 'match';
} else {
$this->_SearchMode = $SearchMode;
$this->FireEvent('Search');
if(count($this->_SearchSql) == 0)
return NULL;
// Perform the search by unioning all of the sql together.
$Sql = $this->SQL
->Select()
->From('_TBL_ s')
->OrderBy('s.DateInserted', 'desc')
->Limit($Limit, $Offset)
->GetSelect();
$Sql = str_replace($this->Database->DatabasePrefix.'_TBL_', "(\n".implode("\nunion all\n", $this->_SearchSql)."\n)", $Sql);
$this->EventArguments['Search'] = $Search;
$this->FireEvent('AfterBuildSearchQuery');
$Search = '%'.$Search.'%';
foreach($this->_Parameters as $Key => $Value) {
$this->_Parameters[$Key] = $Search;
$Result = $this->Database->Query($Sql, $this->_Parameters)->ResultArray();
foreach ($Result as $Key => $Value) {
if (isset($Value['Summary'])) {
$Value['Summary'] = Gdn_Format::Text($Value['Summary']);
$Result[$Key] = $Value;
$this->Reset();
$this->SQL->Reset();
return $Result;
Any help would be greatly appreciated! Thanks!
You can use MySQL like mode with adding this to your conf/config.php. We did this for Japanese installer and it's working for me.
Any clues??
