Who's Online 13
CurtisOdenericgillettejohansonlockerperegrinesethdrebitko +8 guests
CSS issue is causing major permission problems
This discussion is related to the Voting addon.
Hi, I recently installed Vanilla 2.0.18 and voting 1.1.1b, and I've run into a strange problem where users are haphazardly logged out when trying to update their profile or change password.
I figured out the problem: voting.css has a .Loading class which contains a reference to an image that doesn't exist. As far as I can tell, this .Loading class overrides one that is used by change password / edit profile, and when you hit one of those the image comes back with a 404. For some reason, this causes the permission wonkyness.
The fix is to remove the .Loading class from voting.css (or at least the image reference).
Thanks!
