Who's Online 16
CurtisOdenericgillettefh111highwishtc74 +11 guests
patch to fix path issue in plugins/Minify @2.0.18.1
--- a/plugins/Minify/min/lib/Minify/Controller/MinApp.php +++ b/plugins/Minify/min/lib/Minify/Controller/MinApp.php @@ -102,12 +102,13 @@ class Minify_Controller_MinApp extends Minify_Controller_Base { } else { $base = '/'; } - $allowDirs = array(); + $vanillaPath = dirname(dirname(dirname(dirname(dirname(dirname(dirname(__FILE__))))))); + $allowDirs = array($vanillaPath); foreach ((array)$cOptions['allowDirs'] as $allowDir) { $allowDirs[] = realpath(str_replace('//', $_SERVER['DOCUMENT_ROOT'] . '/', $allowDir)); } foreach ($files as $file) { - $path = $_SERVER['DOCUMENT_ROOT'] . $base . $file; + $path = $vanillaPath . DIRECTORY_SEPARATOR . $file; $file = realpath2($path); if (false === $file) { $this->log("Path \"{$path}\" failed realpath()");
When setting up vanilla in the path other than DOCUMENT_ROOT, Minify will return "HTTP/1.0 400 Bad Request" when requesting minified css/js. This is just a quick hack to fix the problem.
