Who's Online 14
BulliesofNCCurtisOdenericgillettefh111tc74 +9 guests
Simple Plugin Help
Yes, another person wanting help to make a plugin. I have looked at the documentation, and unfortunately, I am a teenager and the lack of pictures bores me. I sort of understand how the things work but can't get something to work.
This is to be a simple plugin to check if a minecraft server is online or not. I got the if statement from the web and added the rest to go with vanilla.
So simply I just want to put this in the Panel
< div class="Box MCServer">
<?php
$mc_host=C('MCServer.Host');
$mc_port=C('MCServer.Port');
    < ul class="PanelInfo">
    < h4><?php echo T("Server Status:"); ?>< /h4>
       <?php
       echo $mc_host.':'.$mc_port;
       < /li>
       < li>
       <?php
       if (! $sock = <a href="http://vanillaforums.org/profile/fsockopen">@fsockopen($mc_host, $mc_port, $num, $error, 3))
          echo '< font color="red">Offline< /font>';
       else{
          echo '< font color="green">Online< /font>';
          fclose($sock);
       < /li>
   < /ul>
< /div>
With an option in the dashboard to set the minecraft server's ip/domain and it's port.
Um, yeah, I think that is it. While waiting for answers I am going to have a look at some plugins and see if I can figure it out.
PS I can never get this markdown stuff to do what I want, I want HTML back!
  • 422422
    Posts: 2,109 1 like
    Wrap your code in pre or pre and code tags
    Pre. < pre> hello< /pre>
    Pre and code < pre>< code>hello< /code>< /pre>
    I think
    ♥ I love Vanilla. VanillaSkins | on Twitter | on Facebook | Available Freelance | Take the Vanilla Test | Free Downloads
  • Posts: 157 1 like
    422 said: Wrap your code in pre or pre and code tags
    Thankyou, wikipedia says otherwise
  • 422422
    Posts: 2,109 1 like
    Did it work lol
  • hbfhbf
    Posts: 654 Accepted Answer 1 like
    @clethrill
    try looking at a plugin that adds an item to the panel, such as the who's online plugin. that should give you the info you need regarding hooks to add something.
  • Posts: 157 1 like
    Okay it works! First time I copied the TopPosters plugin and just deleted what I thought was superfluous (love that word) but kept getting bonks, and although changing in the config debug to true it wouldn't show the debug so I just went back looked over it couldn't find the problem and decided to go on a different path.
    This time I jsut copied the TopPosters plugin replaces all TopPosters with MCServer and replaced the TopPosters div box with my one, and voila! Now all I need to do is slowly delete what I think is superfluous. Merci beaucoup pour l'écoute tous les!
  • Posts: 143 1 like
    this is quite an extensive plugin idea, and i love that you pointed out how to get it work, that rocks an i think we are all able to learn from it, thumbs up!
    RedTwentyFour said: this is quite an extensive plugin idea, and i love that you pointed out how to get it work, that rocks an i think we are all able to learn from it, thumbs up!
    @RedTwentyFour That is a very meaningful compliment to me, as will be explained in this brief rant.
    I am do dislike people that go 'HELPZZZ!!! NOW PLZ ????!!!!' and want a plugin and then they go, sorry I am so noob at php.
    I love learning and ever expanding my knowledge of things, albeit am very lazy which will override occasionally. I only know some PHP and learn more as I need it. I am not that familiar with the workings of garden and learn more as I need it. But the thing is that I like to tackle a nice problem. I start of by just making tweaks to other peoples plugins and themes and by having other peoples examples of how they tackled their problems I can see what they were trying to do there and how they did it and then copy and incorporate it into my own. As I get more and more confident I start improving on there methods where I see it, and that is how I become a more knowledgeable person. And that is how I think all people should strive to be.
