@Chanux I wrote the member page on top of the custom pages plugin. I'll probably re-code it as a stand-alone plugin at some point, but I'm not ready to promise a date.
To create a custom page, you really just need to install the custom pages plugin. To do all of the stuff that my member page is doing you need whos online, online user and custom pages, plus my users.php page.
Try installing custom pages and create a simple html/php page.
post the php that you are using for your custom page or post a link to the page. i'm thinking you probably just have an unnecessary DIV in there or something.
@Aolee - I looked at your offering, it looks nice. I wrote mine in about 2 hours, so it's still in work. Mine works a little different too, check it out.
use the custom pages plugin
♥ I love Vanilla. VanillaSkins | on Twitter | on Facebook | Available Freelance | Take the Vanilla Test | Free Downloads
yah im using it now.. but side panel zone is empty
i want to use full size page
or
add side panel to custome page
this is a custom page with no side panel.
http://www.homebrewforums.net/users
is this the kind of layout you are looking for?
if so, it's just a custom page with no render area for the side panel.
It might be helpful if you posted a mockup of what you are trying to do...
wow. its really wonderful. how can i do this. i want use whole page without side panel
@hbf what is this plugin member page
@hbf good work mate.
@422 thanks. still working out some layout bug-a-boos, but it was a pretty quick project really.
i installed custom pages plugin. its working. but side panel area is empty
can i add side panel to custom page (all side panel like discussion page side panel)
how can i use whole page without side panel (like http://www.homebrewforums.net/users)
@Chanux i just realized that i had some css applied to get the full page look on the custom page... sorry about that.
Add this to your custom page
you have to surround it with < style type="text/css"> & < /style> remove the spaces after the <'s
Hi guys,
just incase you're interested i have a browse member plugin here
http://www.goodoldmemories.com/2011/11/browse-members-plugin-for-vanillaforums-2-0-18/
there's also a way to plug a side panel content to it as well.
hope i'm not violating any T&C in posting this. sorry in advance.
thanks.
@hbf i cant understand.. i jest installed custom page plugin.. :(
@hbf you are my............ i don't have words friend. i could fix this problem, using your wonderful concept. thanx again
Thanks, yes I noticed it too that u were able to integrate the online user plugin in your member page. Thats a good concept ;)
