Who's Online 16
CurtisOdenPistachiosUnderDogericgillettetc74422 +10 guests
Nginx problem
Hi everyone,
I managed to install and configure VF (2.1a9) successfully as a root of my domain (non-embedded). Yet certain urls do not work as they should under Nginx (1.0.11).
Here is the example: /dashboard/settings /messages/all
work as they should, however /entry/signout?TransientKey=xxx and lots of other urls with extra parameters after "?" does not work at all. The "signout" does not do its job , however it shows login page as if it already signed out the user. The same goes for entry/register?Target=%2F and other urls I do not remember now.
In a nutshell: no url is working that contains extra ?parameters.
What is the issue and how to fix that? Thanks!
