Using Vanilla With IIS 7
edited March 2012 in Vanilla 2.0 - 2.8
I've just installed vanilla into my iis 7 installation under /forum and i am getting a 404 error (Yes i have done the configuration). I've heard its a prob with .htaccess is there a way to convert it to web.config or turn it off all together
http://apexgames.co.uk/forum/
  • UnderDogUnderDog MVP
    Answer ✓
    IIS isn't even officially supported, I suggest you search the forums for IIS there have been successful installs.
  • x00x00 MVP
    edited March 2012
    you could try renaming the .htaccess, then try.
  • edited March 2012
    I've tried following other people's ways but they don't work. 404 every time.
    Is there a way of turning off these 'special' urls that need rules.
  • After converting the htaccess to web.config i can only go to this
    apexgames.co.uk/forum/index.php?p/dashboard/*
    any thing else 404's. Suggestions?
    Answer ✓
  • chanhchanh OngETC.com - CMS Researcher ✭✭
    I don't mean to bump an old thread but seem like no solution to this post and I think I do have a solution because this work for me.
    On site that run IIS, if you place the web.config file that I attached in to the same place as .htaccess then your rewrite rule should work just fine just like it would on apache
    file: web.config
    <?xml version="1.0" encoding="UTF-8"?>
    <system.webServer>
    </system.webServer>
    It won't let me attach or post the file so I rename the file to .txt so you will need to rename it back to web.config after you get the file.
