[Solved][Documentation] Layout: removing "IP address" from comment info*
I'm trying to find out how to remove the IP address from the info in a comment, which also displays (if you're an admin/mod) "Edit Announce Sink Close Delete Discussion"
I've searched and I can't find it. I'd like to remove the IP address from all comments, I'd like to remove the "Sink" button and if possible I'd like to allign the "Edit Announce Sink Close Delete Discussion" to the right instead of next to the name of the comment poster. Where do I need to look ?
