Hello,
I'd like to put page peel code on my forum. But i didn't found where the head & body tag at any file. Does anyone know?
Thank you.
I'll tell you if you click like :)
I think it would be in vanilla/themes/yourthemseselection /views/default.master.tpl
e.g. if you use the embefriendly theme
head and body are in this file if that is what you mean.
vanilla/themes/EmbedFriendly/views/default.master.tpl
@alanemkay Try the pockets plugin. It gives you a lot of flexibility in managing quite a few things.
@nirav1 thanks to suggest the plugin. Now i got it..thanks again :)
peregrine said: I'll tell you if you click like :) I think it would be in vanilla/themes/yourthemseselection /views/default.master.tpl e.g. if you use the embefriendly theme head and body are in this file if that is what you mean. vanilla/themes/EmbedFriendly/views/default.master.tpl
I haven't the file in my views folder (vanlix theme)..anyway thanks..i found in default.master.php
0 • Off Topic Insightful Awesome LOL •@alanemkay Try the pockets plugin. It gives you a lot of flexibility in managing quite a few things.
0 • Off Topic Insightful Awesome LOL •@nirav1 thanks to suggest the plugin. Now i got it..thanks again :)
0 • Off Topic Insightful Awesome LOL •I haven't the file in my views folder (vanlix theme)..anyway thanks..i found in default.master.php
