Please upgrade to 2.1.x here. The 2.0 branch is no longer being updated.
Current version is 2.1.11, released 12 June.
[Solved] [Documentation] Need help writing an application
edited April 2012 in Vanilla 2.0 Help
Hi all,
I'm trying to write an Application. I'm using http://vanillaforums.org/docs/appquickstart as my guide.
I copy/pasted the applications/skeleton/ directory and changed everywhere the word 'skeleton' existed in that directory to my application name (agvanilla), paying attention to case.
I also changed an erroneous line at the top of class.skeletoncontroller.php from:
$this->Uses = array('Form');
to:
public $Uses = array('Database', 'DiscussionModel', 'Form');
...to mimic the a similar line at the top of the /applications/vanilla/class.discussionscontroller.php file
When I navigate to http://<; ip >/agvanilla/homepage/index.php, I get:
[begin]
Page Not Found
The page you were looking for could not be found.
[end]
If I add var_dump calls to trace the code in class.agvanillacontroller.php, the code in its __construct() and Initialize() function is clearly being executed through to the end of each function.
Help?
Best Answers
  • edited April 2012 Answer ✓
    I finally figured out what was going on. Here's how the file structure needs to be:
    After copying the skeleton application and renaming all references to 'skeleton' to whatever the new controller will be known as ('agvanilla' in this situation) -- paying attention to case -- to be able to go to any of the following eqiuvalent URLs:
    http://<ip>/agvanilla/
    http://<ip>/agvanilla/index
    http://<ip>/agvanilla/index/
    http://<ip>/agvanilla/index.php
    one must create an index method in the class.agvanillacontroller.php:
       public function index() {
           $this->Render();
    and then create the following file:
    applications/agvanilla/views/agvanilla/index.php
    Fill that index.php with whatever HTML you'd like.
    Now navigate to one of those URLs above. Voila, it works!
  • peregrineperegrine MVP
    Answer ✓
    you're the man.
    philAG
  • hbfhbf wiki guy? MVP
    Answer ✓
    Nice simple article on creating an application. Very cool. I may have to try my hand at that. Thanks.
    philAG
