roles & permission problem-'Garden','Conversations','Vanilla' & 'Plugins' not showing after upgrade
fh111fh111 Vanilla Padawan ✭✭
edited April 2012 in Vanilla 2.0 - 2.8
I don't understand why this is happening. I can't manage the roles and permissions for 'Garden', 'Conversations', 'Vanilla' and 'Plugins'.
This is what I expect to see
This is what I see
The community was 'on ice' for 2 months. Back then i was using 2.0.18.1 and i used vanilla porter to export all content.
A week ago i set up a clean install of 2.0.18.1 on our new server, imported the content. then i upgraded to the most recent version 2.0.18.4. then i went to http://mydomain.com/utility/structure
it said:
update GDN_User User set Permissions = '' where Permissions <> '';
i thought that would solve it, but it did not. when i wanted to adjust permissions for a role, i noticed that i can't.
now it only shows the permission settings for one plugin, kPoll - which i installed after i upgraded.
anyone know where the problem could be?
Best Answers
  • peregrineperegrine MVP
    Answer ✓
    also you might reinstall vanilla, download the latest version and see if that fixes it. Someone just mentioned they reloaded it.
    Answer ✓
    Probably happened with vanilla porter - which I never needed to use. They are working on it I believe. Until then probably the thing to do is.
    1 Install latest 2.18 version.
    2 export (dump) the permissions table and save it.
    3 export (dump) the role table and save it.
    4 do the vanilla porter deal.
    5 import the two tables
    6 adjust accordingly in the dashboard any missing roles you created, adjust users to match roles, and category permissions, and fine tune the table that matches the user to the role.
  • fh111fh111 Vanilla Padawan ✭✭
    edited April 2012
    @todd
    @tim
    one of my mods just notified me that he does not even have mod status, even though he has the role 'moderator'. so it seems like i am the only one with rights.
    what can i do?
    edit:
    also, every time i go to http://mydomain.com/utility/structure it wants to perform the same changes. so it does not really apply them
    edited April 2012
    Log in as the root user or the user with the lowest id.
    if it doesn't give you the the full dashboard permissions
    then you could modify the tables themselves.
    They are mustly binary in the permissions table a 1 or 2 in the right most columns give you the ability to do what the clumn title descriptively says. A 0 usually means no.
    look in then GDN_Role` table
    look for administrator role.
    if it is not there create one temporarily with these values
    16  Administrator   Administrators have permission to do anything.  7   1   1
    then go to the user role table
    in column one place yourself (your id) in this example, I am user id 1 with role id of 16
    1   16
    you will now be administrator role.
    in the permissions table change all the columns that start with garden  and vanilla to a 1
    especially the garden settings manage column.
    7   16  NULL    NULL    NULL    0   1
    then as yourself you will now have administrator privs , then go into permissions and roles and clean things up in the dashboard.
    column 7 (vanilla or garden settings manage)  will give you the ability to manage.
    also see:
    http://vanillaforums.org/discussion/comment/157731#Comment_157731
    also I think Underdog created some other documentation in the wiki, but I am not sure.
    edited April 2012
    This should give you an idea. of the permissions layout with 1 designated permission
    GDN_Permission(PermissionID,RoleID,JunctionTable,JunctionColumn,JunctionID,Garden.Email.Manage,Garden.Settings.Manage,Garden.Settings.View,Garden.Routes.Manage,Garden.Messages.Manage,Garden.Applications.Manage,Garden.Plugins.Manage,Garden.Themes.Manage,Garden.SignIn.Allow,Garden.Registration.Manage,Garden.Applicants.Manage,Garden.Roles.Manage,Garden.Users.Add,Garden.Users.Edit,Garden.Users.Delete,Garden.Users.Approve,Garden.Activity.Delete,Garden.Activity.View,Garden.Profiles.View,Garden.Profiles.Edit,Garden.Moderation.Manage,Garden.AdvancedNotifications.Allow,Conversations.Moderation.Manage,Vanilla.Settings.Manage,Vanilla.Categories.Manage,Vanilla.Spam.Manage,Vanilla.Discussions.View,Vanilla.Discussions.Add,Vanilla.Discussions.Edit,Vanilla.Discussions.Announce,Vanilla.Discussions.Sink,Vanilla.Discussions.Close,Vanilla.Discussions.Delete,Vanilla.Comments.Add,Vanilla.Comments.Edit,Vanilla.Comments.Delete`
    Above are the columns
    this is an example of permission id #7 with dashboard settings permissions, you may not need all the columns but they are in the correct sequence.
    "7";"16";NULL;NULL;NULL;"0";"1";"1";"1";"0";"1";"1";"1";"1";"1";"1";"1";"1";"1";"1";"1";"1";"1";"1";"1";"0";"1";"0";"1";"1";"1";"0";"0";"0";"0";"0";"0";"0";"0";"0";"0";"0";"1";"1";"0";"0";"0";"0";"0";"0";"0";"0";"0"
    Cool! Thanks for the input, I will check this out as soon as I have time. Looks promising! : )
    i just tried this and it did not do the trick. is it possible that the error does not have it's roots in the sql? by any chance?
    edited April 2012
    It's always possible it could be something else. I don't know.
    edited April 2012
    // Role Table
    $Construct->Table('Role');
    $RoleTableExists = $Construct->TableExists();
    $Construct
       ->PrimaryKey('RoleID')
       ->Column('Name', 'varchar(100)')
       ->Column('Description', 'varchar(500)', TRUE)
       ->Column('Sort', 'int', TRUE)
       ->Column('Deletable', 'tinyint(1)', '1')
       ->Column('CanSession', 'tinyint(1)', '1')
       ->Set($Explicit, $Drop);
    if (!$RoleTableExists || $Drop) {
       // Define some roles.
       //** Note that every RoleID must be a power of two so that they can be combined as a bit-mask.**
       $RoleModel = Gdn::Factory('RoleModel');
       $RoleModel->Database = $Database;
       $RoleModel->SQL = $SQL;
    //   $RoleModel->Define(array('Name' => 'Banned', 'RoleID' => 1, 'Sort' => '1', 'Deletable' => '1', 'CanSession' => '0', 'Description' => 'Banned users are not allowed to participate or sign in.'));
       $RoleModel->Define(array('Name' => 'Guest', 'RoleID' => 2, 'Sort' => '2', 'Deletable' => '0', 'CanSession' => '0', 'Description' => 'Guests can only view content. Anyone browsing the site who is not signed in is considered to be a "Guest".'));
       $RoleModel->Define(array('Name' => 'Applicant', 'RoleID' => 4, 'Sort' => '3', 'Deletable' => '0', 'CanSession' => '1', 'Description' => 'Users who have applied for membership, but have not yet been accepted. They have the same permissions as guests.'));
       $RoleModel->Define(array('Name' => 'Member', 'RoleID' => 8, 'Sort' => '4', 'Deletable' => '1', 'CanSession' => '1', 'Description' => 'Members can participate in discussions.'));
       $RoleModel->Define(array('Name' => 'Moderator', 'RoleID' => 32, 'Sort' => '5', 'Deletable' => '1', 'CanSession' => '1', 'Description' => 'Moderators have permission to edit most content.'));
       $RoleModel->Define(array('Name' => 'Administrator', 'RoleID' => 16, 'Sort' => '6', 'Deletable' => '1', 'CanSession' => '1', 'Description' => 'Administrators have permission to do anything.'));
       $RoleModel->Define(array('Name' => 'Confirm Email', 'RoleID' => 3, 'Sort' => '7', 'Deletable' => '1', 'CanSession' => '1', 'Description' => 'Users must confirm their emails before becoming full members. They get assigned to this role.'));
       unset($RoleModel);
  • // Only Create the permission table if we are using Garden's permission model.
    $PermissionModel = Gdn::PermissionModel();
    $PermissionModel->Database = $Database;
    $PermissionModel->SQL = $SQL;
    $PermissionTableExists = FALSE;
    if($PermissionModel instanceof PermissionModel) {
       $PermissionTableExists = $Construct->TableExists('Permission');
        // Permission Table
        $Construct->Table('Permission')
            ->PrimaryKey('PermissionID')
            ->Column('RoleID', 'int', 0, 'key')
            ->Column('JunctionTable', 'varchar(100)', TRUE)
            ->Column('JunctionColumn', 'varchar(100)', TRUE)
            ->Column('JunctionID', 'int', TRUE)
            // The actual permissions will be added by PermissionModel::Define()
    // Define the set of permissions that Garden uses.
    $PermissionModel->Define(array(
       'Garden.Email.Manage',
       'Garden.Settings.Manage',
       'Garden.Settings.View',
       'Garden.Routes.Manage',
       'Garden.Messages.Manage',
       'Garden.Applications.Manage',
       'Garden.Plugins.Manage',
       'Garden.Themes.Manage',
       'Garden.SignIn.Allow' => 1,
       'Garden.Registration.Manage',
       'Garden.Applicants.Manage',
       'Garden.Roles.Manage',
       'Garden.Users.Add',
       'Garden.Users.Edit',
       'Garden.Users.Delete',
       'Garden.Users.Approve',
       'Garden.Activity.Delete',
       'Garden.Activity.View' => 1,
       'Garden.Profiles.View' => 1,
       'Garden.Profiles.Edit' => 'Garden.SignIn.Allow',
       'Garden.Moderation.Manage',
       'Garden.AdvancedNotifications.Allow'
    if (!$PermissionTableExists) {
       // Set initial guest permissions.
       $PermissionModel->Save(array(
          'RoleID' => 2,
          'Garden.Profiles.Edit' => 0
       // Set initial confirm email permissions.
           'RoleID' => 3,
           'Garden.Signin.Allow' => 1,
       // Set initial applicant permissions.
          'RoleID' => 4,
       // Set initial member permissions.
          'RoleID' => 8,
          'Garden.Profiles.Edit' => 1
       // Set initial moderator permissions.
          'RoleID' => 32,
          'Garden.Moderation.Manage' => 1,
       // Set initial admininstrator permissions.
          'RoleID' => 16,
          'Garden.Settings.Manage' => 1,
          'Garden.Routes.Manage' => 1,
          'Garden.Applications.Manage' => 1,
          'Garden.Plugins.Manage' => 1,
          'Garden.Themes.Manage' => 1,
          'Garden.Registration.Manage' => 1,
          'Garden.Applicants.Manage' => 1,
          'Garden.Roles.Manage' => 1,
          'Garden.Users.Add' => 1,
          'Garden.Users.Edit' => 1,
          'Garden.Users.Delete' => 1,
          'Garden.Users.Approve' => 1,
          'Garden.Activity.Delete' => 1,
          'Garden.Profiles.Edit' => 1,
          'Garden.AdvancedNotifications.Allow' => 1
    Answer ✓
    Thanks! you set me on the right track. I had a backup of the mysql from before i did the upgrade. so i imported one by one the tables and it seem like the GDN_Permission table was pretty messed up. Took me 5 hours of moving tables around and I don't know how exactly this happened. Happy it finally works, but now i am on 2.0.18.1 .. so i wonder what happens if i upgrade :-D
  • Well Back up all the tables of the working version, just in case. If you are not doing any migration, one would think just overwriting the new source code files of 2.0.18.3 etc. should work. I don't believe you need to do any more utility structure changes, nor should the database be modifed (I am assuming here). Just don't add any more plugins and multiple things. Do one step at a time and test and backup. If after you upgrade to newer version and it works correctly, then you can messa around with any plugins you might want to add.
    edited April 2012
    Thanks for the advice. I am still on 2.0.18.1 though, that was the version we used before the community went on ice for 2 months. Will try to do the 2.0.18.4 update tonight, just to see what happens. of course i made sure i have everything backed up properly : )
  • Once you are on the 2.0.18.x track (e.g. 2.0.18.1) - I don't believe there is a structural change to the databases. I know 2.18.0.3 works fine, and the other versions probably do to.
    cool! i really wonder how this happened then, because I began on the 2.0.18.x track. but as long as it works after updating to 2.0.18.4 i actually don't really care too much.
    Answer ✓
