if you do not have config.php - you have set up your installation entirely the wrong way and you should read the documentation, as well as the installation notes.
\forum\conf\config.php
$Configuration['Vanilla']['Comment']['MaxLength'] = '8000';
1 • Off Topic 1Insightful Awesome LOL •hi,
i only have config-defaults.php but not config.php also, inside there is no
do i have to put that code, or edit it somewhere?
0 • Off Topic Insightful Awesome LOL •if you do not have config.php - you have set up your installation entirely the wrong way and you should read the documentation, as well as the installation notes.
1 • Off Topic Insightful 1Awesome LOL •i followed this http://vanillaforums.org/discussion/19915/deploying-a-new-forum-and-adding-a-theme-for-everyone/p1
the thing is, ive already set up my forum and is live, is there a way to fix this without causing any downtime or reinstall?
0 • Off Topic Insightful Awesome LOL •I would under that circumstance, copy config-defaults.php and rename it as config.php
Don't PM about development, I'm not currently taking on clients.
1 • Off Topic 1Insightful Awesome LOL •if i do what you say, do i just put the code
since, that code wasn't present in the config-defaults.php, if so, where exactly?
0 • Off Topic Insightful Awesome LOL •just put it in config.php, it will be resorted anyway.
1 • Off Topic 1Insightful Awesome LOL •It works perfect @johansonlocker. Thanks alot
0 • Off Topic Insightful Awesome LOL •Option for changing comment length - should be in your dashboard under flood control. may be easier to change there - your choice. :)
yourforum.com/settings/floodcontrol
