Todd: Suggestion for Bonk Page Replacement.
replace error.master.php with this file or something like it.
   <?php
    @ob_end_clean();
    echo '<?xml version="1.0" encoding="utf-8"?>'; ?>
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en-ca">
    <head>
       <title>Bonk</title>
       <?php
       if ($CssPath !== FALSE)
          echo '<link rel="stylesheet" type="text/css" href="',Asset($CssPath),'" />';
    </head>
    <body>
       <div id="Content">
          <div class="SplashInfo">
             <h1>Bonk</h1>
             <p>Something bunky happened. Please bear with us while we iron out the kinks.</p>
             <?php
             if (Gdn::Session()->CheckPermission('Garden.Settings.Manage')){
                     echo "to further debug put these lines in config.php";
                     echo "<br />\$Configuration['Garden']['Debug'] = TRUE;";
                     echo "<br />\$Configuration['Garden']['Errors']['MasterView'] = 'deverror.master.php\';";
                     echo "<br />";
                     echo "if you are changing a theme, the permission the following directories must exist and have permissions of 755.  If 755 does not work for you try 777";
                     echo "<br />";
                     echo "cache/ <br />  cache/Smarty/
     <br />   cache/Smarty/cache";
          </div>
       </div>
    </body>
    </html>
