[gitHub #1385] "Clear activity" does not work
HalfCatHalfCat ✭✭
edited June 2012 in Vanilla 2.0 - 2.8
Hey all!
So, I have a problem with my activity feed. Users cannot delete their "profile activity" they entred. The "clear" link does not work. When you click it, it is removed but after refreshing it is there again. Is this known to anyone or am I alone on this one? Note that this is only for the profile activity that is shown below the user name, the usual activity feed works just fine.
BTW: I can provide a link via PM for anyone to test on your own.
  • peregrineperegrine MVP
    edited June 2012 Answer ✓
    probably be needs to be reported as a bug if not already done so, if it happens in current version.
    what version of vanilla are you using. It may have been fixed.
    here's the table and column to clear for the particular user.
    table - User
    column - About
  • Do you mean in the share box? I noticed this a while back. I went into mysql and modify the database to remove it. Neve bothered to look at the code.
  • Yes, in the share box...
    table - User
    column - About
  • HalfCatHalfCat ✭✭
    edited June 2012
    All right, created a bug report on git. Thanks for your help. It is only on a test system, so no need to delete in the database (yet).
  • SheilaSheila ✭✭
    edited June 2012
    Have noticed this same error/bug. I'm running on 2.0.18.4 if that helps.
  • its nice to get questions answered :)
