Problem save questions
edited June 2012 in Vanilla 2.0 - 2.8
Buen dia.
Tengo una duad con el pluggin kpoll. No me permite agregar preguntas. cada que agrego una no se guarda.
Alguien me puede ayudar con eso.
Gracias
Good day.
I have a doubt with the plugin kpoll. It allows me to add questions. I add one each not saved.
Someone can help me with that. thanks
    edited June 2012 Answer ✓
    not an answer - but a heads up - looks like it has a security problem -
    http://www.henryhoggard.co.uk/category/security/
    Ya vi tu enlace. pero no existen los otros sitios que menciona la pagina.
    You saw your link. but there are other sites that mention the page.
    Gracias, lo solucione descargando la version 1.1
    Seguia dando problemas con la otra version asi que opte por cambiarla y si funciono.
    Thanks, I solved by downloading the version 1.1
    She kept giving problems with the other version so if you choose to change it and it worked.
