Need help in embedding vanilla forum with a question2answer website
Need help, people ... I already have a question2answer website and and I have installed a vanilla forum too. As you know that there is an embed plugin at vanilla forum that enables embedding the installed Vanilla forum into a remote web application.
A javascript code has been given to embed and it says 'Copy and paste this forum embed code into the remote application where you would like the forum to appear' .. My question is where to put that code on my question2answer website so that the vanilla forum gets embedded ? Do I need to make a new plugin for it ?
  • peregrineperegrine MVP
    Answer ✓
    why don't you guys just tell us how you solved things, because invariably another user months from now is going to ask I had the same problem how do I fix. just makes it easier. All questions asked and then solved by the same person, should provide the solution as a courtesy to others,
    UnderDog
