Is it possible to override an already declared Controller method?
businessdad
Stealth contributor MVP
After a short absence, I'm back with my odd questions. This time I'd like to override ProfileController_Discussions method, but, obviously, I cannot just redeclare it as Vanilla doesn't like having such a conflict.
What I need to do is changing what happens when User opens the /profile/discussions/ page. It's not just a matter of cosmetic changes, I really need to change the logic, therefore I have to implement a Controller.
At the moment, since the "brute force redeclare" doesn't work, I created a Controller with a slightly different name and it works, but it would be nice if it were possible to avoid this workaround.
As usual, thanks for the help.
We don't really allow redeclares like that right now. Doing what you did is a good idea and you could complete the whole thing by also adding a route that maps /profile/discussions to your new method.
@Todd Thanks for the answer, at least I know I made the right choice. By the way, how do I add the route you mentioned?
My shop | About Me
There is a routes link in the Dashboard. You can use regular expressions in it so you can make something like
/profile/dashboard(.*)
point to/profile/dashboard2$1
.@Todd Thanks, I never noticed it. I learned something new!
My shop | About Me
best do the route like so
^/profile/discussions(/.*)?$
->/profile/discussions2$1
ok it is unlikely that you will have something else with discussions, but it good practice any way.
@x00 I tried to configure the Route as you described, but, if I try to open /profile/discussions, that's exactly the page I get, I don't get routed to my other Controller method. Do I have to enable something to make the routes work?
My shop | About Me
No I made a mistake there is no leading slash
^profile/discussions(/.*)?$
->profile/discussions2$1
@x00 I'm sorry, I feel quite dumb, but I don't seem to be able to make it work.
To recap, since I can't override Profile_Discussions, I implemented a Profile_DiscussionsList, which can be accessed as /profile/discussionslist. I tried to add a route, so that anyone accessing /profile/discussions would be redirected to /profile/discussionslist, but I can't figure out the syntax.
I thought something like
^profile/discussions(/.*)?$->profile/discussionslist2$1
would work, as it looks like a normal regex to me, yet I get a 404 when I try to access the routed address.Sorry for this repeated question and thanks again for the help.
My shop | About Me
take the 2 out
profile/discussionslist$1
you are not going to profile/discussionslist2/blah/blah blah
you are not going to profile/discussionslist/blah/blah blah
if I answered the question and it worked and saved x00 some time responding maybe he could help me with my asset question - please
If I didn't solve it maybe x00 could help please help me with my asset question
A-ha! I didn't spot it! I'm getting old... Thanks for the tip.
My shop | About Me
