[Solved] How to fix Broken URLs, broken bbcode etc. after Conversion
FanboyNYCFanboyNYC newb
edited July 2012 in Questions
In the past few days, I have been pushing to make a move from PHPbb to Vanilla. A move for me was a big decision, seeing as my forum has been running since 2004. (If I had to start a forum from scratch, vanilla would be my choice hands down.)
I used the porter plugin, and I was able to work on the design to where I need it.
Now my only issue is, the majority of my links are broken. Once clicked, it seems to refresh to the same page. When I look at the code, it is [url= etc. I have issues with codes and broken smileys (which I don't mind).
I have the NBBC installed, as well as Quotes; however, the issue remains.
I really want the urls fixed.
If anyone can suggest anything, please reply, thank you.
