Current Markdown heading vs edit vs hashtag problem - Needs modification Lincoln, Todd Tim
test results at this link
Heading seems to work when the # is in first column - perfect.
hashtag is assumed if greater than second column, fine. but...
a) final hashtag is ignored.
b) upon editing (without modification) the first # gets purged off of every item (or it seems so).
c) search with hastags has bug.
%23 needs to be removed-- see (problem in 2.1 and 2.0.18.4)
http://vanillaforums.org/discussion/comment/166099/#Comment_166099
1
Sounds like the good topic for a detailed GitHub issue.
I've never posted anything in github. Maybe I'll give it a try.
If only there was a genie that automagically did it.
A rare and mythical beast.
