Role specific background color in posts.
keesha
Hello,
I'm looking for a way to get a different background color for moderators like you can change it in wordpress with the author css tag.
Possible?
Optionsperegrine MVP
get the role title plugin and add
http://vanillaforums.org/addon/roletitle-pluginput something like this to custom.css in your theme
li.role-moderator {
background: green; }I may not provide the completed solution you might desire, but I do try to provide honest suggestions to help you solve your issue.
2
li.role-moderator {
Holy cow, worked like a charm.
Thank you
Awesome!
