problem with Headcat?
"The requested URL /teste/vanilla/vanilla/settings/categoryheadings/HeadCat/1/1 was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
This is show when I try active 'heading' in category, Any solutions? Thanks for advancing.
  • out of interest is this your directory structure?
  • I have the line
    url: gdn.definition("WebRoot")+'/vanilla/settings/categoryheadings/'+cat+'/'+id+'/'+on
    try pointing in your browser to
    /teste/vanilla/settings/categoryheadings/HeadCat/1/1
    You don't need RewriteUrls to be on but you do need you server rules to be working. In some case they aren't check for .htaccess if using apache.
    I presume you are using 2.0.18.4
  • Sorry for lack of details and yes I use 2.0.18.4.
    About the directory is </teste/vanilla/>
    When put /teste/vanilla/settings/categoryheadings/HeadCat/1/1, give me same error.
    Not Found
    The requested URL /teste/vanilla/settings/categoryheadings/HeadCat/1/1 was not found on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.>
  • well there is some issue with rooting or your server rules.
  • Re-install vanilla 2.0.18.4 and created new database, works fine now.
