How does it work? (¿Como funciona?)
YAcosta
I implemented the plugin, but I see what your operation. Will conflict with CLEditor doing?.
ORIGINAL:
He implementado el plugin, pero no veo cual es su funcionamiento. ¿Estara haciendo conflicto con el CLEditor?
The plugin should not interfere with CLEditor.
All it does is, if you have a link in your post such as
http://www.youtube.com/watch?v=CLUUxKF1DrI
it will convert it to an embed.
If you have vanillaforum's Youtube embed disabled, this plugin should start doing the Youtube embeds.
A longer explanation is at http://minelord.com/discussion/149
If friend, I did, but I can not see any effect, not that I'm doing wrong, if you have a time my forum is: www.poreltube.net
You can use the user: testing
and the password is 123456
thanks
You need to set
$Configuration['Garden']['Format']['YouTube'] = TRUE;
in
conf/config.php
to disable Vanilla's in-built Youtube embedding.This will allow for my plugin to work with Youtube videos.
Other embeds work.
ooohh. Ok, I'll make that adjustment
@swook
I like your website design. looks nice. and nice demo for the plugin in your discussion link.
You put the line, it works perfect for everything now in this case:
http / youtu . be/yzOF3g97euo
works well, but with
http://www . youtube . com/watch?v=yzOF3g97euo
the maximized does not work, but that was from before.
thank you very much
@peregrine: Thank you!
@YAcosta: What browser and OS were you using?
Use more and got it. I tried it with Chrome, Mozilla, IE y Maxthon
Sorry, I meant
$Configuration['Garden']['Format']['YouTube'] = FALSE;
IS PERFECT!!! THANKS VERY MUCH!!!!
Your plugin works great, I'll put it in my blog too vanillaforo.com to be known.
