My Vanilla forums will not work on a mobile.
DenisSDenisS My brain hurts Buriram ✭✭
Is there a fix for this my mobile is Android don't work get "Bonk" my mate's is I phone the same. I have read so many things but they all seem to go off in a tangent. Google says robots.txt maybe be the problem I have tride a few but they don't work. Is there some code somewhere to paste in the body?
Best Answers
    See if this info helps
    http://vanillaforums.org/discussion/comment/171195/#Comment_171195
    have you tried implementing any themes? do they work ? bonk can be anything
    edited February 2013
    Thanks for your answer, vrivlinder
    To explain, I'm working on 7 expats forums for a North East Thai area. all work on laptops / desktops and 6 give a bonk error one gives this error, Oh by the way i'm not great at code but i can get by:
    Fatal Error in Smarty.trigger_error();
    Smarty error: the $compile_dir '/home3/hannahas/public_html/korat-expatsforum/cache/Smarty/compile' does not exist, or is not a directory.
    The error occurred on or near: /home3/hannahas/public_html/korat-expatsforum/library/vendors/Smarty-2.6.25/libs/Smarty.class.php
    I'm trying to locate this now. But looking at it it looks like a differnt error Than just a mobile one.
    businessdadbusinessdad Stealth contributor MVP
    As the message says, you must make sure that you have a cache/Smarty/compile directory in your Vanilla folder, and that such directory is writable.
    If you don't have that directory, just create it and set write permissions on it. That should solve the error.
    I have checked the dir is there to make sure i over wrote it. But>" that such directory is writable???? and set write permissions on it" ?? not sure what this means.
    My son who used to the coding has disapeared in a beer bottle so i'm left to learn to part of the forums, coding which i'm having to learn it's only been two weeks So i need all the help i can get, Cheers a 66 year old expat from England!
    Ok your problem is that you need to create a folder in cache called Smarty then another one in that folder called compile.
    does not exist
    This means you must create it :)
    You mean just create dir in cache with nothing in them? or copy the whole file in?
    And both these dir in Cache?
    Smarty-2.6.25
    SmartyPlugins
    thanks vrijvlinder, i'll try that and see how it goes
    Yea no content in those folders
