Does Vanilla 2.0.18.4 work with ProxyConnect 1.9.9?
Looking at the database it never creates the new user either.. but the VanillaProxy cookie is created. Any hints?
Figured it out. Bug in ProxyConnect @Tim -- > If two users have the same name it just doesn't log them in, it should throw an error, or you should assign a number.. something. Or this should go into technical documentation.
I was wrong still doesn't work with different names. Any ideas... Maybe its flood control?
I was having the same problem until I added this to config.php:
$Configuration['Garden']['Cookie']['Domain'] = '.mydomain.com';
Now it works fine.
I'm having the same issue -- I confirmed that I have that cookie domain set at you mentioned, zeldatron.
Anyone figure out how to get this to work? jared?
Further information:
The forums are hosted in a virtual host that is a sub-domain of the primary site:
http://forums.crushlivepoker.com/
The cookies in the VF ACP for the ProxyConnect plugin are set to:
.crushlivepoker.com
I also verified that the cookies in the config.php file match:
$Configuration['Garden']['Cookie']['Domain'] = '.crushlivepoker.com';
The data returned from the Authenticate URL http://www.CrushLivePoker.com/site/forumsso looks correct:
UniqueID=4 Name=andrew Email=xxx@xxxxx.com
I'm a little confused as to why the Test ProxyConnect button in the ACP returns:
"It doesn't seem like we were able to retrieve a logged-in session from the AuthenticateURL you specified. Please make sure you are logged in to your remote application before performing this test.
NOT LOGGED IN"
Thanks, doublepost. I'll close this one.
