Embedding comments (wordpress) modification location help
johnnyzen
anyone help me with this?
@Shadowdare is the wp -vanillaforums integration guru. You should look at the amazing melding he did with his new site.
http://vanillaforums.org/discussion/comment/184339/#Comment_184339
