Make Categories Horizontal Instead Of Vertical and Move Upper Level
digihubdigihub New
edited May 2013 in Vanilla 2.0 - 2.8
How can I make the categories horizontal instead of vertical?
And how to move all to upper level (between head and content)? Thanks in advance.
BEFORE:
Resepi Restoran Terbaik! Resepi Restoran Terbaik!
AFTER:
  • Can anyone help please?
    edited May 2013
    well the easiest way to do it I think is to use the categories drop down plugin and modify the script part to say display in-line and keep them visible at all times.
    You might need to use some css to get it right but it could work.
    '< script type="text/javascript" >
    var ddmenuitem = 0;
    var menustyles = { "visibility":"visible", "display":"in-line", "z-index":"9"}
    function Menu_close()
    {  if(ddmenuitem) { ddmenuitem.css("visibility", "visible"); } }
    function Menu_open()
    {  Menu_close();
       ddmenuitem = $(this).find("ul").css(menustyles);
    jQuery(document).ready(function()
    {  $("ul#Menu > li").bind("mouseover", Menu_open);
       $("ul#Menu > li").bind("mouseout", Menu_close);
    document.onclick = Menu_close;< /script >'
  • Thanks @vrijvlinder. Let me try and see what happen...
