Add Content Right After Body And "before" Content (before) pocket
Adrian
Wandering SpiritMontreal MVP
Hi,
I love Pockets, but I am stumped at how I can add a 728x90 banner just below the Body, and above the Content (before) Pocket. Ultimately the banner should be just below the nav bar. Any hints or tips welcome
I know it's probably a stupid question, but why is Content (before) not the right place? From the screenshot, I imagine it would look as you expect.
My shop | About Me
You could also modify your template file to include the banner area.
never mind. misread your question - thought you wanted it below discussiontabs.
looks like the place to me too!
if I put this for example in the content beforepocket.
it puts it in the spot - if you really need to move it up a dom element
for some unknown reason.
you could use jquery
if you are concerned that the banner interferes with panel on right - you could drop the panel with padding:top by 90 px.
@peregrine, I guess that would be the best bet. I was hoping there was a way to create a pocket called "bannerhead", or something. You are right about the panel on right being the issue. I need a 728x90 banner. The 468 fits fine. I don't want to hardcode though, I am using using pockets, as it allows me to turn the banner off and on as needed.
I think the space you want to put that falls under Head so if you choose Head as the spot it should output it under the menu.
If the menu comes out after it,you can switch that in the theme master or maybe add another function to render after menu, or maybe add Menu as a $Location in the array of the class.pockets.plugin
I would just create an html div in my master in the area before the menu div.
div class="BannerImage"
< div >< img class="BannerImage>< /img >
the css
div.BannerImage{
position:relative;
top:60px;
margin:0 auto;
height:90px;
width:728px;
img.BannerImage{
height:90px;
width:728px;
border-radius:2px;
You could also add a transparent banner logo in the dashboard the size you want and use css to add the image as a background of the clear one
@vrijvlinder thanks for the tip. I just wanted to follow up with how I solved thanks to your help. I added a new location called "HeaderAd" to the class.pockets.plugin, then in my theme, I created a div called "HeaderAd"
And then I was able to use the pocket as I needed. Thanks again for pointing me in the right direction.
Awesome , I don't think there is anything that can't be done in Vanilla, just have to find the way
