Would appreciate help finding a suitable tool to debug.
I really like the Split/Merge FE plugin, as it offers the option to move comments into existing threads.
Unfortunately it doesn't work in 2.1, and I don't know if the original author intends to update it.
Clicking Move is meant to bring up a form, the same as Split does, but it only brings up a very small box that you can only close.
(See here: http://vanillaforums.org/discussion/23816/splitmerge-fe-1-01-on-vanilla-2-1b1-move-comment-not-working#latest for an image.)
Is there a suitable tool I could use to see what is happening to stop the form from rendering properly?
None of the Firefox developer tools I've looked at seem to do the job.
As always, any help appreciated.
Thanks.
  • businessdadbusinessdad Stealth contributor MVP
    I didn't have a look at it, but Firebug is the best tool I can think of, for JavaScript. It's possible, however, that the issue is in the PHP code, due to the differences between 2.0 and 2.1.
  • whu606whu606 I'm not a SuperHero; I just like wearing tights... MVP
    @businessdad
    Thanks for the reply.
    Nothing I can see in Firebug seems to track the events.
    @whu606 Do you use FireQuery with Firebug? I find it useful for debugging JS.
    Regardless, you should be able to look in the console to see if a response is malformed. The uri that is POSTed relates to a specific function on a specific controller in a specific application.
    P.S. I am pretty sure you know this stuff already :D
    @hgtonight
    I actually don't know any proper coding at all.
    I can hack my way through where there are models to work from, without ever really understanding the 'why' of things.
    I shall have a crack at FireQuery.
    If you post the net request in the console, I can point you to the right spot in the code. :D
    @hgtonight
    Well, baby steps are being made!
    Both the Split (which works) and the Merge (which doesn't) make similar requests:
    GET http://localhost/2.1new/vanilla/moderation/splitcomments/5734?DeliveryType=VIEW
    GET http://localhost/2.1new/vanilla/moderation/movecomments/5734?DeliveryType=VIEW
    However, only the Split produces any HTML code, which is, of course why the Merge form doesn't show properly.
    As to what is causing that...
    Well, I shall stick my head under the hood, and hope to see a loose lead.
  • peregrineperegrine MVP
    edited May 2013
    problem I believe is in line 131 or vicinity
    call to a member function Put() on a non-object.
    in class.splitmergefe.plugin.php
    if ($Sender->Form->ErrorCount() == 0) {
                    $ResultDiscussionID = $ResultDiscussion->DiscussionID;
                    $CommentModel = new CommentModel();
                    $CommentModel->SQL
                        ->Update($CommentModel->Name)
                        ->Set('DiscussionID', $ResultDiscussionID)
                        ->WhereIn('CommentID', $DiscussionCommentIDs)
                        ->Put();
    edited May 2013
    something wrong here WhereIn and $DiscussionCommentIDs
    if you change it to Where - you don't get error, but you lose functionality.
    $DiscussionCommentIDs - is probably null.
    edited May 2013
    Or, perhaps, CommentID is an ambiguous columns. I stumbled upon this type of issue in the past. In Vanilla 2.1, for some reason queries are written as
    Apart from making little sense to me, they can cause the "ambiguous column" error. More specifically, in case of discussions, DiscussionID would exist in both d and d2. Perhaps the issue is related to a query like
    In such case, you can try changing WhereIn('CommentID', $DiscussionCommentIDs) to WhereIn('c.CommentID', $DiscussionCommentIDs) and see if it works.
    Note: I didn't look at the code yet, I'm just speculating.
    edited May 2013
    good point. but in this case ....
    I would think the problem lies with $RequestArgs pulling wrong discussion id - consequently $DiscussionCommentIDs is null which leads to
    null PUT
    http://vanillaforums.org/discussion/comment/183775/#Comment_183775
