Questions or Issues for VFonts
Please post your feedback for this plugin here, thanks for trying it.
It basically just changes then font face for the forum.
    A few notes:
    1. Does the license on these fonts permit redistribution?
    2. I like that you include a different style sheet for mobile
    3. Your first if statement will always evaluate to true
    4. The first clause in your second if statement will also always evaluate to true
    5. I like the icon
    6. If it is mobile, both stylesheets will be added
    The reason 3 and 4 always evaluate to true is because it checks the return of the assignment operation. You can var_dump($Controller); before and after that if statement to make it more clear.
    Suggestion to solve 3, 4, and 6:
    public function Base_Render_Before($Sender) {
      if($Sender->MasterView != 'admin') {
        // Only add the style sheet on the frontend
        if(IsMobile()) {
          $Sender->AddCssFile('plugins/VFonts/vfm.css');
        else {
          $Sender->AddCssFile('plugins/VFonts/vf.css');
    I understand if you want to keep it controller based, in which case you should use InArrayI($Controller, $ArrayOfControllers) as your check. Also add 'discussionscontroller' and 'postcontroller' to your list.
    edited July 2013
    These fonts are free and redistributable, I added only a couple as example, but people need to add their own.
    http://www.acidfonts.com
    The first clause in your second if statement will also always evaluate to true,
    I was not aware of that , the mobile style sheet did not show as being called on the web inspector.
    It really does not matter if both are called, they contain the same info. I just wanted to be certain they did get called :)
    I like the icon
    thanks it is a rip of an existing free icon, I made this plugin late last night and was too tired to make a totally origin one. :(
    Oh ? did not check that however like I said, the mobile and the full contain the exact same info, until I find other potential things in the mobile theme that I did not include in the list. Good to know that at least it is being called no?
    Excellent !! I will work on it asap, I will be traveling tomorrow so today I have a bunch of things to get ready. Hope by monday something will have been done :)
    Well it is not a requirement , but I thought what if they may not want font change on something so they can eliminate that controller from the array.
    Based on what you pointed out I am wondering how it even works at all lol !!
    I knew I was missing a couple !! thanks :)
    edited July 2013
    @hgtonight,
    I have updated the plugin with your suggestion and removed the controller array which may prove unnecessary unless they want some other font on another page, which is rare no? If they want that I suppose they can ask for it and look here for the mod. This plugin was meant as a simple way to switch fonts so no need for extra baggage....
    Thanks again for the help !!
    The regulars here, yourself included, have really helped me step up my game. I am always happy to help appreciative people! :D
    edited July 2013
    It has improved my game as well - Dodgeball. i feel i can dodge anything now!
    But when it comes to futbol and basketball - I see absolutely no improvement in my game. still no one chooses me for their team in pickup games.
    Ok maybe I'm being thick, but when I download this to a mac, the zip file doesn't open... your last zip 'marquee' plugin unzipped fine just seconds before I found this plugin ?
    check the file size of the file you downloaded vs. the files size indicated in the description.
    if they don't match you may have an incomplete file and need to re-download.
