Best way to have "blocks" in panels section
Hi
What is the best way to implement html "blocks" on the side panels? In CMSs like Wordpress you would call it a widget or in Drupal a block. I would like the ability to create "blocks" in Vanilla to put general text or html or adsense/amazon code.
Any advice?
  • peregrineperegrine MVP
    edited December 2013
    not sure what you mean. have you looked at pockets plugin?
    http://vanillaforums.org/addon/pockets-plugin
  • Thanks
    Will try it out.
    What I mean is, if you look to the left of this site, you will see a Vanilla Help banner and then at the bottom left a follow us section, the ability to add "blocks" as in Wordpress with widgets or Drupal with Blocks etc.
    I can obviously amend the theme to include/hard code such blocks of content but if there is a plugin that can do it similar to other cms, therefore from the Vanilla community what is best practice for these forums.
  • Wait a minute I just discovered the Messages section under appearance. :#
    This will work.
  • R_JR_J Ex-Fanboy Munich Admin
    It is not as easy as using a cms but is not too hard either...
    vanillawiki.homebrewforums.net/index.php/How_to_Build_a_Simple_Module_and_Integrate_it_as_a_Plugin
