Does split merge work in vanilla 2.0.18.10 ?
omakis
After upgrading from 2.0.18.9 to .10 split merge is not working.
Is it normal or my problem ?
It should still work.
Did you go to
/utility/update
?Try disabling and re-enabling the plugin.
I did the /utility/update with success, disabled and re-enabled split merge still not working...
What happens (or doesn't happen)?
Need some detail here
Actually when I have a clean install split merge works but after I import my database and enable the plugin, then even it shows enabled it does nothing.
There are no little tick boxes next to options, in discussions.
What does your
/conf/config.php
file look like?Please remove any sensitive information before posting it here (account names, passwords, salt, etc.).
It worked after a new install.
Thank you
