How to work with tags?
Hi, i'm ultra new to Vanilla
I'm attempting to do a sort of home page, but I can't understand the way tags work.
To keep this entry short:
-I need to know where is the file that has the control of the {asset name="Content"}
-I need to get the tags so I can print the "Most Recent", "Popular" and if possible get some of the "Categories" to put in the home page.
( I'm guessing something like {asset name="Popular"} )
Thanks in advance
    Welcome to the community!
    What version number of Vanilla are you running?
    You most likely want to set your homepage to /categories/all and find some plugins that list discussions in the side panel. I would suggest the Latest Post List and Hot Threads plugins.
    edited May 2014
    In addtion to hgtonight's comment.....
    It's fairly unclear where and what you want to do (at least to me).
    or are you talking about your own custom home page.
    use the basic pages plugin
    or extrapages plugin
    or see these
    http://vanillaforums.org/discussion/comment/195082/#Comment_195082
    http://vanillaforums.org/discussion/comment/206099/#Comment_206099
    or are you talking about smarty template tags. which you can search for tutorial and discussions about those.
    http://vanillaforums.org/discussion/20231/how-to-become-somewhat-adept-at-modifying-vanilla-to-meet-your-needs-for-free
    or are you talking about adding modules in panel.
    Thanks!
    I'm on Version 2.1
    Those plugins seem like a good option.
    However, I need to create a totally costumed home page, in previews versions of vanilla, I find they had a "Enter the url to the page you would like to use as your homepage" field, but not in this one.
    So i'm modifying the "default.master.tpl" but don't know to make it work as a simple homepage, whatever I do to this file will be in every page of the forum.
    Let me restructure my question:
    Where and how can I crate a file to call inside the {asset name="Content"} as a homepage?
    And inside this file, I need to call the "Most Recent", "Popular" and only 2 categories that need to be displayed in the home page.
    Thanks for your help.
    edited May 2014
    perhaps reading the above comments again might give you some insights :)
    content is just the center (not a panel on the left). it doesn't have to do with "home" vs non-home pages.
    do you want your site without panels.
    you need to make up a mockup screenshot. (in this case a picture of what you want is worth 10 million words).
    This is what i'm trying to achieve
    http://community.ubnt.com/
    I guess this isn't Vanilla
    But this is sort of the things I need in the homepage
    They have some categories in the top, just the latest post in the content area and the ability to post custom content
    I try changing this
    $Configuration['Routes']['DefaultController']= array('categories', 'Internal');
    in te config file
    into my home page.
    But it did not work.
    Hope you guys can help.
    PS: By the way, I read the discussions you post earlier, but I did not get anything I can use ("ultra new to Vanilla")
    In this case, I would check out the Nilla Blog plugin, or the upcoming Articles application.
    You could probably hack something together with the Custom Pages plugin as well.
    I personally use a plugin I wrote called Blander Blog, although I eagerly await the Articles application.
    Hi guys
    Thanks for your help, it was really helpful, I even find other things I did´t know I want haha
    I came up with the solution:
    -Install the Custom Pages plugin.
    -Create a Home page with it.
    • Go to the Routes Settings and edit the settings for that new home page
    • Change the "Route Expression" to "DefaultController"
      And that's it (so far)
    Hope this info is useful for other new Vanilla users out there
    Thanks again for your help
    I have realized now that I change the topic of the question...
