How to use sub script and super script
How to use sub script and super script in Vanilla 2.1
x 2
x 2
x [sub]2[/sub]
x [sup]2[/sup]
Best Answers
vrijvlinder Papillon-Sauvage MVP
`<sub>subscript</sub>` `<sup>superscript</sup>`
<p>This text contains <sup>superscript</sup> text.</p>
needs to be wrapped in html
http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_sup
5 -
peregrine MVP
see
http://vanillaforums.org/addon/mathjaxcdn-plugin
for inputting info like
[Math y = \frac{1}{x^2-1} \hbox{ when $x \ne \pm 1$.} ]
with [Math ...... ]
6
subscript
superscript
This text contains superscript text.
@vrijvlinder It's not working..
It may not be allowed here. What formatter are you using what editor ?
vertical-align: baseline;
How to remove this CSS style..@vrijvlinder I'm using ButtonBar..
It is very strange because using cleditor it shows up in the editor but when posting it the html tags get stripped.
I had the same problem using
<video>
or<audio>
tagsIt shows in the editor but gets stripped when posting it. I could not guess why. This works on github and other places but not here or in my forums.
Maybe @Linc has a clue? I do have those elements allowed in the config.php.
use the mathjax plugin.
http://vanillaforums.org/discussion/comment/199690/#Comment_199690
@peregrine How to use mathjax on vanilla 2.1
Take a look at these resources
http://www.mathjax.org
http://docs.mathjax.org/en/latest/community.html
http://www.mathjax.org/community/mathjax-in-use/mathjax-in-use-instructions-and-how-tos/
@vrijvlinder I can't enable Latex plugin.
why are you trying to enable Latex . you don't need it.
follow the instructions in the following thread and it will work
see
with [Math ...... ]
