How to Include Colored Boxes in Forum Posts ?
onesoftindiana
Can some body tell me how to include colored text boxes in forums like this forum has included - http://forumias.com/discussion/381/new-to-forumias-please-read-this-rules-of-posting-in-the-forum
You can set this via custom css rules in custom.css of your custom theme.
See here:
http://vanillawiki.homebrewforums.net/index.php/Custom_Themes_2
Learning to use a web-inspector, such as Firebug in Firefox, will help you to identify which elements need to be changed/
with the info whu606 gave you and the plugin here you should be able to figure it out.
example of changing background based on user role.
http://vanillaforums.org/discussion/28278/post-background
