Trouble enabling plugins and changing themes
somwhatparanoid
Evening everyone,
I'm using Vanilla 2.1.8, the latest release pulled from GitHub. I seem to be having troubles when enabling plugins and changing themes - it takes several clicks to enable a plugin, and when it does get enabled, it usually gets reset to disabled once I try to enable another or reload the page. Theme changes also take two clicks to update, so it seems that those issues are related. I tried on two different browsers (latest Firefox and latest Opera) and on two different computers and the problem is the same. Does anyone know of a fix?
Thanks.
Yes, you probably have some kind of opcache enabled, which caches the config.php.
http://stackoverflow.com/questions/13456475/how-to-exclude-php-file-from-apc-cache
My themes: pure | minusbaseline - My plugins: CSSedit | HTMLedit | InfiniteScroll | BirthdayModule | [all] - PM me about customizations
VanillaSkins.com - Plugins, Themes and Graphics for Vanillaforums OS
