How to hide views and comment
Hi,
I bet there is an easy way to do that, but cannot find it anywhere.
I need to hide views and comments form discussions board as on screenshot.
http://imgur.com/Be2RJHx
Because I using statbox.
Thanks in advance
Lucas
    Great thanks a lot.
    BTW, do you know how to make a little white gap between those two blue stats boxes like on this forum here?
    Regards
    Lucas
    @lucus78 said:
    Great thanks a lot.
    Regards
    Lucas
    You are looking to increase the margin between the boxes.
    http://www.w3schools.com/css/css_margin.asp
    Thanks all done it
