Blank Discussion Body
thejason40
Hi.
Bit of a strange request but is it possible to allow the body of a discussion to be blank as long as it has a title? Thank you
it can look blank, but without a code change you can't leave it empty.
I guess you might be interested in this discussion: http://vanillaforums.org/discussion/14175/disable-the-body-is-required-message
Thanks for that, it worked like a charm. I had searched already but couldn't find it. Now I just need to move a few things around on the page. Namely, 'DiscussionHeader' needs to be above 'PageTitle'. Hopefully this won't be too hard to do if I can locate the right file.
do you just want the title repeated in body if null body? (effectively similar without getting rid of Page Title.).
